Author Topic: Charge controller sizing  (Read 1672 times)
getvrtcl
  • USMC 1976-1986
« on: October 13, 2011, 10:03:24 AM »
I am concerned about the sizing of a charge controller.  I have 4 of the panels below hooked in parallel.  I am running 4  T-105 (12vt) for batteries.  I will never increase the size of the system for this building and I would like a trouble free controller.  I am concerned with what amp controller I will need.  I have a cheap Sunforce 30 amp I would like to use, just because I have it.  If I am reading amps right I should be able to because Ip 6.82 X 4 = 27.28   So I think I can get away with any controller rated at 30 amps or above, RIGHT????
EC-120-GL
Pp        120
Vp        17.6
Ip        6.82
Voc        21.5
Isc        7.68
Cells        72
Obama proves there is an ASS for every seat.
Re: Charge controller sizing
« Reply #1 on: October 13, 2011, 11:06:31 AM »
I would recommend going with Isc, then adding 20% just in case.
4 x 7.68 x 1.2 = 37A
That's up to 40A class.
dave ames
« Reply #2 on: October 13, 2011, 01:32:35 PM »
If you are in a pinch.. might consider running three panels through the controller and one directly into the battery bank with a diode while waiting for a proper controller.
one unregulated module on a bank that size should be ok. (my opinion only)
Fun stuff, dave
