I have built my rotors but yet to install the magnets, still have to remove from the last set of rotors. I am holding off to build the stator, yet to determine the coil specs, as I have purchased a Midnite Classic 150 for this turbine. I'm still in the middle of researching optimal voltage yield for this controller. Also hoping I will have a little more experimental room for blade size and type with the Classic which may allow me to run a faster Dan's style blade and use a " clipper " of sorts to control top end. Anyway.
