The springs did get hotter than I was expecting. If I use it much more, I am going to have to do some redesign. I had it mounted on a 2x6 with some 3/8" bolts. It only had about an inch of clearance between the spring and the wood. Pretty scary to leave it that way unattended.
Thanks to everyone who responded. After looking at my drawing and hearing what people said, I see why the voltage was up. I didn't take the time when I saw the voltage that high to measure the battery. Not quite panic mode, but was thinking the worst. I am going to go see if I can get some resistors after lunch and make another attempt.
I looked at the three hours or so of data I got while it was attached. It did get my RPM up quite a bit. From 250 max RPM to around 320 RPM with the line resistance added. I can't tell what power improvement there was because of the inaccurate voltage level I was seeing.
I always said that you learn more from your failures than you do from your successes, so I guess I am learning an awful lot...
![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
Again, thanks for the help.
Mike
