Day late and broke as a joke, but wanted to comment on this... for future readers.
WPC= ? I didn't do the math but my guess would be watt hours per cell?
Actually, common rating system for industrial UPS batteries. In his case, rated for 15 minutes of power (typical UPS usage).
You're close - but it's just Watts Per Cell, and refers to a given, constant, high discharge rate. Watt-hour doesn't imply the constant rate, nor the 'high'. The goal was to make a capacity rating that a given UPS system can provide as accurate as possible (supposedly).
The hightest charge rate I see was 13.2v, that was with the inverter turned off.
Something tells me this was spot on - three things come to mind:
1 - We're talking 200AH of battery here. Speculating (based on the loads and times given) implies a fair drop in SoC during the use, exacerbated by #B
#B - Chances are, the engine was idling during all of this, so power output from the alternator was a minimum.
4 - Doubting that anybody hung around afterward with the inverter turned off and engine idling for two hours; Even I don't have that kind of patience.
I can't count. Sue me.
So, 13.2V 'lightly' charging from an idling engine makes sense. The OTV on the truck battery suggests the same; 12.45V would indicate it never got filled back up before the engine was shut down.
The only discrepancy I can see with all of this is the 14.8V at the truck, and 13.2V at the SLAs. Then again, it isn't entirely clear if this is during the same time frame or not.
Crappy cables would also provide a dent in the logic if they
were measured at the same time...
Steve
