Hi all,
I have a small turbine installed on my sailboat using a 30V Ametek DC motor, and I want to make sure my charge control setup won't fry my batteries. Can the collected wisdom here please check out my setup and let me know your thoughts?
-- 30V Ametek DC motor, directly tied to 12V batteries through blocking diode and 20A fuse.
-- Charge controller connects to battery bank, then to a dump load consisting of 2 50W lights. When battery voltage reaches the trip point (~14V), the controller turns the lights on (using battery power, NOT generator power) until the battery voltage drops below the trip point. The generator always supplies power to the battery and never to the dump.
Does this control/dump scenario work assuming that the two lights sufficiently siphon the excess battery charge off the top of the bank? Do I need to worry at all about the fact that as much as 30 volts are pumping into my 12V batteries for sometimes hours at a time? Does input voltage even matter (aside from efficiency) so long as the battery capacity isn't overcharged?
In good winds I can clearly see the lights turn on and off periodically, so the setup appears to be working as I planned. However, one of the batteries in my bank turned out to be bad last month (no idea how long this was the case), and I want to make sure I didn't murder it by accidentally thinking I was clever.
Thanks,
Jeff
