i may have been overly broad with my comments, in that
i am probably overly critical of some of the claims i have seen from some
of these companies.
when you see claims of a kwatt or more from a baby delco altenator modified
with neo's and driven by a set of blades i am automatically suspect.
me and automotive alternators go way, way back, having rewound them for various voltages from 12volts at lower rpm, to as much as 480 volts at 600rpm and everything between, i just don't see them as a viable windpower unit, most especially those anemic little delco's, unless
ones need is realistically somewhere around 50 to maybe 100watts? then maybe
however, for the amount of money and time to get one up and flying safely the same money could have been spent on a good solar panel and one would likely get far more power with far less work.
now if someone comes up with a wind unit that can provide 4krpm to an alternator
with perhaps 3.5kwatts of mechanical power, i can provide you with alternators that will make nearly 3 kwatts for a 24volt system charging at 28.8vdc and 100amps. and do this without neo magnets.
or one can scale it anyway he wants to, the key here is one needs the higher rpm in order to get into a useful power range and get the efficiency needed to make it worthwhile.
so far i have not seen many diy'er capable of building a transmission of suitable ratio that is relatively high in efficiency, low in maintenance and rugged enough to do the job reliably. that is so far ![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
getting back to the little pm modified alternators, one of the sellers of these units was going on about how his unit could make some insane amount of amperage, i don't recall how much because i was put off by his claims. quick math in my head clearly indicated that one might not get 1/8 the claimed output in reality, and that is just no where near honest in my books.
bob g
