I assume you read about diodes:
http://www.fieldlines.com/story/2005/3/10/202925/513
Other devices, like SCR, MosFET, IGBT etc can do the same job, typically with two issues:
First, requires control circuit to actively trigger conduction called active rectification.
Secondly, cost more than a diode.
Diode current ratings must be 2x worst case. Life tends to surprise you. 2X helps. If you really think you know what your doing then 1x, as a designer the cost difference must be large for me not to use at lease 1.5x.
Diode voltage rating, this can be surprising. 12V wind turbine with 5mph cut in. Again diodes must be rated for worst case voltage. Wind turbine is outputting 12v at 5mph wind, at 10 24v, 20 =48v etc. Furling hopefully will limit the top RPM at some point in the 20's MPH. Lets say 25, voltage is 60v, Use NO less then 120v diode. Price of 200v or 400v is not much. Exceeding the voltage rating burns up the diodes in most cases. With wind turbine connected to the battery, the diodes will never see the larger voltages. Wires break, stuff happens. With a clear mind could not used diode below 200v in a 12v system. 400 in a 24v, 600v in 48v. Diodes rated above 600v start costing more.
With line losses and wind turbine matching issues, worrying about the voltage drop in the diode is wasting you time/money. To understand why will require understanding the whole system. Complex.
Have fun,
Scott.
