Author Topic: Doc Wattson meter  (Read 1497 times)
Otto
Doc Wattson meter
« on: January 02, 2008, 02:47:21 AM »
Does a shunt resistor have to be purchased along with the Doc Wattson meter?http://www.powerwerx.com/product.asp?ProdID=34677
Thank you,
Otto
« Last Edit: January 02, 2008, 02:47:21 AM by (unknown) »
DanB
    • otherpower.com
Re: Doc Wattson meter
« Reply #1 on: January 01, 2008, 09:00:20 PM »
No...
« Last Edit: January 01, 2008, 09:00:20 PM by (unknown) »
coldspot
« Reply #2 on: January 01, 2008, 11:02:21 PM »
A question ?
 For R.E. use, would you get the
   "Doc Wattson"
or the
   "Watt's Up"
Being the same price only a few differences
They both look great but I've been wondering what one to order,,..   ???
« Last Edit: January 01, 2008, 11:02:21 PM by (unknown) »
$0.02
Otto
« Reply #3 on: January 02, 2008, 05:38:02 AM »
Dan, thank you for your reply regarding the Doc Wattson.  With this meter would I be able to monitor the amps/volts going into my battery bank and also the amp hours of the battery bank?  Electricity is not my strong point.
Thank you,
Otto
« Last Edit: January 02, 2008, 05:38:02 AM by (unknown) »
snowcrow
« Reply #4 on: January 02, 2008, 06:35:35 AM »
  The "Doc Wattson" is a better choice for RE because it records 100 time more amp hours and also records in Kwh, thus it doesn't have to be reset as often.
  The "Watt's Up" is better for trouble shooting, with it's peak watts recording.
Blessings, Snow Crow
« Last Edit: January 02, 2008, 06:35:35 AM by (unknown) »
snowcrow
« Reply #5 on: January 02, 2008, 07:15:37 AM »
  Hey DanB, I have a question for you.  Are you using the 4 wire or the 3 wire configuration for battery charging?  They say in the documentation that the 3 wire is best for high current applications, so I tried the 3 wire hookup and it seems to work fine.  It should run cooler under high current conditions.
  Do you see any potential problems that may arise using the 3 wire hookup for charging?
Snow Crow
« Last Edit: January 02, 2008, 07:15:37 AM by (unknown) »
