Hi, I have a couple of old, fused, knife type safety switches I'd like to use in my hydro system.[500 watt output, smartdrive alternator rectified to dc, 48 volt battery bank, apc matrix 5000 ups as invertor] One uses cartridge type fuses, the other screw in type fuses. I'm aware that I need to use DC fuses. One of the safty switches only has AC ratings, If I'm able to find dc fuses that fit it, is it safe to use? Should I lower the Volt/amp rating by some factor for Dc? Are there AC vs. Dc issues regarding the knife switch and fuse holders as well as the fuses themselves? Does anyone know of a source for screw in type fuses with DC ratings? Thanks for any help,
David
