Thanks for the comments Todd. Each coil has 70 turns. I also have a stator using 20g wire with 115 turns. The tower should withstand very strong wind: the anchors should hold over 9000 lbs. The cable is rated for 1400lbs SWL. The trees are a problem, unless you like trees which I do. I hope the winter will work out well without the leaves.
I had a good wind recently, but I did not have an anemometer. I do now. The blades were rotating about 200rpm. What do you suggest for blades? Bigger diameter? Airfoil types?
At this time I am not close to 1000w. Time will tell...
