Author Topic: DC-Motor  (Read 1517 times)
Tommy L
DC-Motor
« on: August 18, 2004, 11:29:07 PM »
Hi !
I purchase this on a ad in the local newspaper for $15. I have try to spin by hand with a 12v lightbulb and it shine quite bright.
So what are you out there saying, is this something to try build a small windgenny with or ?
Tommy L  /Sweden
<BR><img src="http://www.otherpower.com/images/scimages/631/DC_motor_24v_liten.jpg" width=80%><BR>
<BR><img src="http://www.otherpower.com/images/scimages/631/DC_motor_24v_skylt_liten.jpg" width=80%><BR>
« Last Edit: August 18, 2004, 11:29:07 PM by (unknown) »
Tommy L
Here is Picture!
« Reply #1 on: August 18, 2004, 11:39:10 PM »
« Last Edit: August 18, 2004, 11:39:10 PM by Tommy L »
Re: DC-Motor
« Reply #2 on: August 19, 2004, 04:18:48 AM »
 Can't read the the plate but I would say go for it . See how many bulbs you can power up and how much torque you need to start making power got to match the size requirements of your blade and wind availability.
« Last Edit: August 19, 2004, 04:18:48 AM by tecker »
Re: DC-Motor
« Reply #3 on: August 19, 2004, 04:24:21 AM »
   Got it 24 volts at half an amp .Wire is small and the output will be low . Maybe a fun project ?
« Last Edit: August 19, 2004, 04:24:21 AM by tecker »
drdongle
Re: DC-Motor
« Reply #4 on: August 19, 2004, 05:20:32 AM »
It's a TDM or Tape Drive Motor
Carpe Vigor
Dr.D
« Last Edit: August 19, 2004, 05:20:32 AM by drdongle »
Re: DC-Motor
« Reply #5 on: August 19, 2004, 03:38:08 PM »
Good for about 6 watts into 12 volts at about 200 RPM, 12 watts into 24V at about 400 RPM.
Not a lot of power.  But with steady wind it would bring an 85 amp-hour battery from 80% discharged to full in about a week.
I had a boat that used such a battery for running lights and the like, which got used mostly on weekends, and ran after dark or anchored out with an anchor-light on, and used the VHF radio, often enough to use a lot more than leakage current.  Came with no charging system at all.
Rather than hook up the charging circuit from the auxiliary outboard, provide a shore power charger or clip one on, or what-have-you, I used a little solar panel with about half that output, and a little regulator to prevent overcharge.  Never had a problem with dead battery over the several years we had the boat.
A little wind genny based on that motor (maybe put up when the boat was put away for the week, stowed below decks when under weigh) would have done just as well.
It won't power your house.  But such a "toy" mill should have plenty of uses nontheless.
« Last Edit: August 19, 2004, 03:38:08 PM by Ungrounded Lightning Rod »
Tommy L
Re: DC-Motor
« Reply #6 on: August 19, 2004, 11:57:30 PM »
Thanks for all the response, I probably put it up as maintenance charger for the tractor and boat battery in our summerhouse during the winter.
/ Tommy  Sweden
« Last Edit: August 19, 2004, 11:57:30 PM by Tommy L »
wpowokal
Re: DC-Motor
« Reply #7 on: August 20, 2004, 05:43:07 AM »
my money is on it being 5A not as name plate says 0.5A. Size is similar to all TDM's I have seen good for 5-10 amps.
« Last Edit: August 20, 2004, 05:43:07 AM by wpowokal »
Barnac
Re: DC-Motor
« Reply #8 on: August 20, 2004, 06:12:32 AM »
Is not it 3 watts in 12 volts ?
« Last Edit: August 20, 2004, 06:12:32 AM by Barnac »
Re: DC-Motor
« Reply #9 on: August 20, 2004, 11:17:21 AM »
Nope.
You can still let the mill speed up until you get the half amp.
« Last Edit: August 20, 2004, 11:17:21 AM by Ungrounded Lightning Rod »
