HI Flux, Ghurd and everyone!
I just ran the lamp ( lightbulb test) I could only find a 12v light bulb from out of my tractor. I hooked up two leads off the stator to the bulb and gave it a spin....as you folks say it felt lumpy but it sure was bright! SO I'm thinking everything is good with my stator/rotor setup. So now I need to get a book "meter reading for dummies"!
The mulitmeter ( analog style)has only two places for the leads + & -
However when I set the meter on 50 AC and spin the rotor fairly fast by hand it gives me a reading of 8 on the scale, however just above this 8 is another number 40, so my question is this: If I have the meter set on 50AC that would say the meter would read up to 50 volts AC, correct? Then the number I was reading as 8 volts was actually 40 volts correct?
Since I have passed the light bulb test, and the Meter is set on 50AC and if my hunch is correct about reading the meter correctly this time, I can say each phase is generating 40 volts AC? for a total of 120 volts AC?
PLeeeease tell me I fianlly correct in all of this )
If I am indeed finally correct in all of this, I need to go back and review Ghurds power calculations when it rectifies into DC voltage
