Hi, I am very new to windmills, I have been doing some research on the internet. I would like to eventually try an axelflux? windmill. At the moment I am trying to make a windmill from a DCPM Motor. I have 2 Motors, 1 is an argord 2 1/2 hp 130volt dcpm motor, 18.5 amp. The other motor is a baldor motor, 90 volt .8 amp motor. the argord motor is not putting out enough volts, with low speed drill motor I am getting about 11 volts, and plenty of amps, it will light up a car headlight, no problem, The baldor, puts out 20 volts, but minimal amps, .8 and will light a turn signal bulb, as for a headlamp, no way hosay! Any suggestions would be helpful I am thinking gear up the argord with maybe bicycle gears and chain, and shoot for 15 volts, and go with maybe 4' or 5' foot blades to spin it? Any help would be highly appreciated, Thank You
