Author Topic: DIY Water Wheel  (Read 10047 times)
Pogster
DIY Water Wheel
« on: January 22, 2007, 01:12:54 PM »
Just finished my 1st revision of a DIY water wheel, the wheel delivers about 2A into my 12V battery pack. It is made entirely out of surplus pallets + an ametek tape drive motor....
Links:
http://www.youtube.com/watch?v=P7A_4VP6V80
http://www.youtube.com/watch?v=KLvsixjlYIo
http://www.youtube.com/watch?v=z900AKfwC5Y
Pete.
« Last Edit: January 22, 2007, 01:12:54 PM by (unknown) »
Re: DIY Water Wheel
« Reply #1 on: January 22, 2007, 07:22:37 AM »
Hey Pete, It looks good!
How big is it?
It will be interesting to me to hear suggestions for improvements.
I am wondering about that 'flap-flap-flap' sound.  If the buckets were sharpened to catch more water a bit sooner and less turbulent, maybe the output would go up a bit?
I don't know.
Welcome!
« Last Edit: January 22, 2007, 07:22:37 AM by ghurd »
dudevato
Re: DIY Water Wheel
« Reply #2 on: January 22, 2007, 08:32:04 AM »
Pete, That thing is great!  If it was mine I'd set there with a cup of coffee or a beer (depends what time of day) and watch it for an hour or so. Really Cool!
« Last Edit: January 22, 2007, 08:32:04 AM by dudevato »
gotwind2
  • ben[at]gotwind.org
Re: DIY Water Wheel
« Reply #3 on: January 22, 2007, 09:21:27 AM »
Great work - and it would be running 24 hours a day I presume?
Nice alternate use for the Ametek motor - shame there aren't more of them about, especially in the U.K. :-(
Ben
« Last Edit: January 22, 2007, 09:21:27 AM by gotwind2 »
Re: DIY Water Wheel
« Reply #4 on: January 22, 2007, 10:25:36 AM »
Looks great, nice videos.  Have you had any problems with debris in the stream?  24 Watts, 24/7 that's nice.  I wonder how long the pallet wood will hold up, did you coat them or protect them with anything?  Rich
« Last Edit: January 22, 2007, 10:25:36 AM by richhagen »
Pogster
Re: DIY Water Wheel
« Reply #5 on: January 22, 2007, 02:41:34 PM »
Rich,
Quite a lot of leaves but these don't seem to be a problem. We had a great deal of rain last week that raised the stream level above the wheel - this left a lot of debris on the wheel - branches etc.. once cleared it worked fine again.
The wheel slats are made from Indian Hardwood pallets (everyone in the UK seems to be using Indian stone for driveways!) and I have treated them and the plywood with Thompsons water seal.
Pete.
« Last Edit: January 22, 2007, 02:41:34 PM by Pogster »
Pogster
Re: DIY Water Wheel
« Reply #6 on: January 22, 2007, 02:51:45 PM »
The wheel is about 2ft diameter and 2.5 feet width. Now the wheel is properly loaded (and spinning slower as a result) the noise output is much less.
I'll try and sharpen the edges to see if that improves things.
« Last Edit: January 22, 2007, 02:51:45 PM by Pogster »
Titantornado
Re: DIY Water Wheel
« Reply #7 on: January 22, 2007, 05:37:15 PM »
I think I'd only have one suggestion to offer, since you mention the overflow due to high water.  Why not build a swing-arm for it, with floatation?  This way, it could "ride" the flow height as needed, and not get swamped and packed with debris.
« Last Edit: January 22, 2007, 05:37:15 PM by Titantornado »
dennisbuller
Re: DIY Water Wheel
« Reply #8 on: January 31, 2007, 02:24:41 PM »
Greetings Pete,
   What is the gear ratio for the wheel to generator?
   What is the normal rotation per minute of the wheel?
Thanks!
Dennis
« Last Edit: January 31, 2007, 02:24:41 PM by dennisbuller »
Pogster
Re: DIY Water Wheel
« Reply #9 on: February 06, 2007, 01:19:51 PM »
The gearing is in two parts a 1:2 set of cogs and a 1:10 set of sprockets and chain giving me 1:20. The wheel spins at about 60rpm under no load. I've not measured it with the gears and motor connected but would estimate about 40-50rpm.
Pete.
« Last Edit: February 06, 2007, 01:19:51 PM by Pogster »
GerryS
Re: DIY Water Wheel
« Reply #10 on: February 11, 2007, 04:52:24 PM »
That looks great.  I have two treadmill motors I'm trying to do the same thing with.  I want to bring one with me to this mountain stream my family goes camping at.  What does the base of the wheel look like?  I only see one board coming up to the motor?
« Last Edit: February 11, 2007, 04:52:24 PM by GerryS »
Pogster
Re: DIY Water Wheel
« Reply #11 on: February 19, 2007, 08:54:32 AM »
I made two L shaped brackets out of hardwood with a 45 degree insert to firm everything up. The whole lot is bolted together with M10 bolts.
Marine ply on the base and this is bolted down to bedrock.
Pete.
« Last Edit: February 19, 2007, 08:54:32 AM by Pogster »
GerryS
Re: DIY Water Wheel
« Reply #12 on: February 27, 2007, 02:41:02 PM »
ooooo...bolted down to bedrock.  I guess that's not going anywhwere!
« Last Edit: February 27, 2007, 02:41:02 PM by GerryS »
doug1232
Re: DIY Water Wheel
« Reply #13 on: May 04, 2007, 11:27:16 AM »
Hi Pete,
I'm a editor at Popular Science magazine in the U.S. and would be interested in hearing more about the water wheel--can you get in touch with me via e-mail?
Thanks a lot,
Doug
« Last Edit: May 04, 2007, 11:27:16 AM by doug1232 »
