Author Topic: Pipe blade stringth.  (Read 2285 times)
« on: July 27, 2009, 02:39:19 AM »
I made a set of the normal ZUB-WOOFER pvc pipe blades. I've also made a set of basicly the same blades but with the foam pipe.
I tested both in the wind tunnel on my 8" duel rotor genny. Both blade sets did 30 volts at 11 mph no load. I havn't done the loaded test yet.
I wanted to test the stringth diferance between these 2 plastic pipe blade. So I mounted them horizontily and added weight to the tip. I used a 5lb brick.
The standard PVC pipe blade is abou 1/8" thick. The foam pipe is 5/16" thick.
The skin wall on the foam pipe is less than 1/32" thick with foam between the iner and outer walls. The foam pipe is very strong but at the same time very light.
I'll take a few pictures.
« Last Edit: July 27, 2009, 02:39:19 AM by (unknown) »
Re: pictures.
« Reply #1 on: July 26, 2009, 08:54:50 PM »
I'll be testing these blades under load and compairing the to carved wood and my "Jerry Blades".
These are all 4ft blades tip to tip.
« Last Edit: July 26, 2009, 08:54:50 PM by Jerry »
fabricator
  • My smoke got out again
Re: Pipe blade stringth.
« Reply #2 on: July 27, 2009, 02:19:24 PM »
Is there a thread somewhere on how these blades are made?
« Last Edit: July 27, 2009, 02:19:24 PM by fabricator »
« Reply #3 on: July 27, 2009, 03:03:36 PM »
fabricator try this. http://www.fieldlines.com/story/2007/2/2/41629/53700
I used a Rotozipe with router blade to make the curved slot for the blade root.
The wood triangle is a stack of 3/4" plywood. I'll be trying a 6ft, 8ft and a 10 ft with this build.
« Last Edit: July 27, 2009, 03:03:36 PM by Jerry »
Chuckrunyan
« Reply #4 on: July 27, 2009, 09:19:26 PM »
Hi Jerry
When you say you will be trying a 10 ft with this build do you mean 10 ft diameter or 10 ft blade length?
Thanks.
Chuck Runyan
« Last Edit: July 27, 2009, 09:19:26 PM by Chuckrunyan »
« Reply #5 on: July 28, 2009, 07:57:45 AM »
Hi Chuck.
I get this question frequently. Thats why most of the time I use the expresion
tip to tip. Its funny I think I'm the only one that uses that term.
10 ft tip to tip, 5 ft blades or as the Dans would say a 10 footer. Maybe 10 ft turbine?
This may be a good blade for my new 14-11 NEO genny?
« Last Edit: July 28, 2009, 07:57:45 AM by Jerry »
georgeodjungle
« Reply #6 on: July 28, 2009, 10:16:40 AM »
i use sch40 sdr, better uv resistant. the flexibility is about the same. use it's flex to your advantage to change tsr. i.e. variable pitch blades.
plus at about 40-50mph it starts to act as a brake.
more free power & safer,, ya got ta love that.......
« Last Edit: July 28, 2009, 10:16:40 AM by georgeodjungle »
« Reply #7 on: July 29, 2009, 12:11:08 PM »
Uh...Jerry ?? 5ft. blades would be 10 ft.
diameter (swept area)...but if you have a
triangular hub...you must have 3 blades and
measuring from one tip to another will be a lot
less than 10 ft. ??
(back to my building battery boxes before you get mad or disgusted with me )
only came in because of a smell of Skunk de Cologne
out in my shed...but now it's raining and
washing the smell away Hooray !
« Last Edit: July 29, 2009, 12:11:08 PM by Norm »
