Author Topic: Motor conversion, many 3-phase's to pick from????  (Read 1632 times)
coldspot
« on: May 15, 2006, 04:33:07 AM »
I finally got to see my girlfriends brothers stash of motors today!!!
He has a bunch of 3-phase ones that he said he will never use and I
could play with them !!!!   :)~
There was a couple of half HP's, and a one HP with a few 2 HP's.
Now I just need to pick out one to start on ????
I'm thinking that I should be looking for a lower RPM model and maybe
to go ahead and try to get a half HP with a 2 HP also.
Of course I'll have to hook him up with one after I get one done and
prove that I'm not just talking!
Good thing his cabin is just a few hundred yards from her's!
(He does have a much better site for a windmill as far as open area
and no tree's, She of course had to have her's built in the middle of the forest and has many HUGE tree's all around it. But I still like her's much better, lol, :)   )
« Last Edit: May 15, 2006, 04:33:07 AM by (unknown) »
$0.02
coldspot
Re: Motor conversion, many 3-phase's to pick from
« Reply #1 on: May 15, 2006, 08:31:42 PM »
Any advice out there on what to look for when picking out some motors?
I'm sure lower RPM's would be good but
also I'm thinking shaft size and frame type might place issues
when looking them over?
« Last Edit: May 15, 2006, 08:31:42 PM by coldspot »
$0.02
wdyasq
« Reply #2 on: May 16, 2006, 08:37:17 AM »
Coldspot,
I'm not an expurt on conversions.  I do remember from reading you will want as low a speed motor as you will probably find. I think Zubbly said the "2 pole" - 3450 rpm +/- on 60Hz motors were not desirble.  You will want as large a shaft as you can get.
As I remember Zubbly is getting about a kW/HP from his conversions. The curved magnets would need to be near rotor diameter if you chose to use them.
« Last Edit: May 16, 2006, 08:37:17 AM by wdyasq »
coldspot
« Reply #3 on: May 17, 2006, 02:32:29 PM »
Thanks Ron-
Was pretty much what I thought and have read
was hopeful that zubbly would reply
« Last Edit: May 17, 2006, 02:32:29 PM by coldspot »
$0.02
« Reply #4 on: May 17, 2006, 04:25:40 PM »
I'll have a try at it. Anyone feel free to shoot me down (I will learn something).
Low RPMs is better, but anything works (at least to some extent, and better than I expect... even mine!).
All "X" HP motors are not created equal. Some have a much higher coil resistance than others.  I would try the low resistance motors of the same HP rating first.
Then I'd ruin the others in order!  Low resistance motors die first!
No idea if that train of thought is correct.
Bigger is not always better.
You (meaning me) will have trouble with too low of a cut in speed and needing blades too large for what you can use (meaning what I can use here).
Or the power curve is too steep, needing larger blades than you can use (again meaning what I can use here).
You (again, meaning me) will build some alternators twice as good as a stepper motor, and only half as useless.
You (meaning me again) will build some wonderful alternators, quite accidently, that have great potential for wind use (meaning neither you, or I, can use them).
Ain't it great being us?
If us is we, then go clean out my garage!
« Last Edit: May 17, 2006, 04:25:40 PM by ghurd »
DanG
« Reply #5 on: May 18, 2006, 08:20:22 AM »
Just observations I've noted along w/ above recommendations...
Sealed end caps w/ cooling fins - all weather motor makes good all weather generator.
Cast housings w/ beefy mounting bracket built in - stamped brackets spot welded to motor housing require precautions as the steel / welds won't hold up well.
Shaft diameter .625" or greater - and as long as possible, once can always trim but adding to 7/8" stub isn't feasible.
If you only have a minute to choose before the dogs wake up or somesuch, smell check the motor for burnt phenolic smell. Toasted windings trump other quick check guidelines...
« Last Edit: May 18, 2006, 08:20:22 AM by DanG »
coldspot
« Reply #6 on: May 18, 2006, 10:58:18 AM »
Thanks people !!!
ghurd-
Because I don't have a garage, you'll have to clean out your's yourself, lol
(wish i had a place like that to play in!!!!!!!)
DanG-
Na, the dogs know me and I'll get to pick them over, (after I dig them all out,lol)
maybe, after I get them all out, I'll get them all!!!! (wishful thinking going on)
I should be able to pick at least a few up very soon, (week or so) and then I'll have more info and fun. !!!
« Last Edit: May 18, 2006, 10:58:18 AM by coldspot »
$0.02
coldspot
« Reply #7 on: May 21, 2006, 07:25:20 PM »
3-Phase Motors
Picked up today !!!   :)
Two 2 HP's
First one
Baldor Industriel
cat# "M3157T", Fram "145T", spec "35Bo1-754"
ser "F684", HP 2, Volts 208-230/460
Amp 6.8-6.4/3.2, RPM 1725, Hertz 60, PH 3, class B
ser.F. 1.15, Des B, code H
Second one
Gould Century
part "8-331259-03", frame N145T, type SC
HP 2.0, volt 230/460, Hertz 60, PH 3
Rpm 1745, Amp 6.0/3.0, code L, Time Con
There was another 2 HP there but was smaller shafted
and being that girlfriends other brother wants to also
follow along and do one himself, I left that one for him
Also a couple 1 HP's and a half HP but left behind for later use maybe
Now just waiting for them to dry out after being filled with engine degreaser
foam then sprayed out at car wash, can see that they might need another wash down.
Just trying to play and have some wind type fun, lol
« Last Edit: May 21, 2006, 07:25:20 PM by coldspot »
$0.02
