honestly, i disagree with the sealed (SLA) batteries. if the charge controller is set just a bit too high, it'll boil them dry, or if they get out of balance, there isn't really much equalizing that can be performed.
i think there's a reason most all offgrid setups use flooded lead acid. you can beat them up, drain them too low, and then just boil the snot out of them to bring them back. if you visit your place once in the spring, once in fall, and once in the summer, that's plenty of times to check/add water. with a properly designed system, you should only have to water them 2-3 times a year MAX.
i personally like FLA batteries much better as they seem harder to kill, and easier to resurrect if you've almost killed them. make sure to set the equalize to manual, so your controller isn't boiling them once a month while you aren't there for months on end.
my offgrid place is unoccupied for months at a time during the heart of the winter, and the heart of the summer. i check water levels everytime i'm there, and equalize 3-5 times a year. i only add water 1-2 times a year to my FLA bank and have never had an issue.
but this is all my opinion.
adam
