Author Topic: 28v regulator?  (Read 1436 times)
(unknown)
28v regulator?
« on: November 22, 2005, 05:05:59 PM »
    Does anyone know where I can get a regulator for my 28v 200amp surplus aircraft generator? I want to run it off a 600cc 12hp 2cyl water-cooled Kubota diesel engine to charge my battery bank.
« Last Edit: November 22, 2005, 05:05:59 PM by (unknown) »
maker of toys
Re: 28v regulator?
« Reply #1 on: November 22, 2005, 12:32:05 PM »
Try "trade-a-plane"
or barnstormers:
http://www.barnstormers.com/cat.php
everett aero:
http://www.everettaero.com/
or google 'aircraft salvage"
you'll need the part number and maybe the serial off your gen head when you go to talk to these guys.
Good Luck!
« Last Edit: November 22, 2005, 12:32:05 PM by (unknown) »
Clifford
Re: 28v regulator?
« Reply #2 on: November 22, 2005, 06:12:00 PM »
WHEW
You could look at some heavy equipment regulators (catepillar, truck, etc).  Or, the aircraft regulators.  However, they may not do what you want as they would be designed for on-all-the-time operation which may not meet your needs.
Does your regulator have to regulate the field coils?  Throttle?
However,
I wonder if you would want to design something specifically for intermittent duty power generation rather than what an auto/truck/tractor/aircraft regulator would do.
What is the max charging amps to push into a standard battery?  Don't they reccomend between 2-8 Amps / battery?  Do you have enough batteries to distribute the amps?
Are you planning an auto-start on the generator?
Consider designing a regulator:
10.5/21V --> Start the generator if not already running (or your desired low voltage).  Push your field coils to max.
12.3/24.6 (or so) --> reduce power to field coils, let off of accelerator
12.6/25.2V (or high resistance) --> turn off the generator.
Note,
If you are pushing too much current to the batteries, it may be difficult to get an accurate reading of the voltage, although I assume the current drops as you approach full charge.
« Last Edit: November 22, 2005, 06:12:00 PM by (unknown) »
alain
Re: 28v regulator?
« Reply #3 on: November 22, 2005, 07:34:08 PM »
hello.
i am working on something similar, 220 amps @28 volts generator ,
from an army tank i believe, i will drive it with a 13 hp horiz. shaft engine similar to gx390 honda. the voltage regulator is mounted on the generator.If i have a chance this weekend ,i will post pictures of what i try to achieve. I also want to build a wind genny to charge a very large  battery bank. I will use a pm motor 48volts@1000 rpm.With a 5000 watt inverter that will make the bulk of my system.
So far: 13 hp motor new        $325    CA
        220 amp gen.like new   $205    CA
        pm motor A1 cond.      $135    CA
        UPS inv. 3000 watts    $???
        Battery bank           $2000?  CA
        Everything else        $????
This is where i am so far.
I still need blades and so on.
I do have a 28 volts generator  100 amps double pulley from a military truck with the regulator i haven't used in 4 years, perhaps that would fit on your gen.
I have fitted a 60 imp. gallons electric hot water tank on a epa rated wood stove.
it gives more hot water than i need.
I also have a solar water heater in the works.
lots of fun,
good luck
Alain
« Last Edit: November 22, 2005, 07:34:08 PM by (unknown) »
Experimental
Re: 28v regulator?
« Reply #4 on: November 23, 2005, 10:16:04 AM »
    Hseaver, Hi..
    California airframe parts Co. (Calif, jobbing corp.)
    72 - 98th ave.
    Oakland , California..
    I think the phone no is 569-4011, but can,t remember the area code!!
   They had a lot of these regulators, for aircraft, etc...and are selling out, old stock --- Ask for Ted -- they may fix you up, resonably...  Bill H......
« Last Edit: November 23, 2005, 10:16:04 AM by (unknown) »
