Author Topic: Check out what I found on www.ti.com  (Read 1015 times)
ibedonc
« Last Edit: October 06, 2004, 08:29:18 PM by (unknown) »
JW
  • Development Manager
    • Flashsteam.com
Re: Check out what I found on www.ti.com
« Reply #1 on: October 06, 2004, 08:54:55 PM »
Wow, the pdf downloaded nicely for me.
 Just cought a glimpse of it. That'll Take some time to digest.
JW
« Last Edit: October 06, 2004, 08:54:55 PM by (unknown) »
hvirtane
    • About Solar Cooking
« Reply #2 on: October 07, 2004, 09:37:10 AM »
I also downloaded the stuff.
The circuit looks to be quite complex,
but otherwise the article looks to be good.
I will try to study it more later.
« Last Edit: October 07, 2004, 09:37:10 AM by (unknown) »
RatOmeter
« Reply #3 on: October 07, 2004, 09:41:53 AM »
I likes it.
I think the first section is a must-read for everyone here who might be fiddling with lead-acid batteries in their long-term setup.  It explains an (the?) ideal charging process.
If the specialized components used are not too out-of-date (document written in 1999), I'd like to built this circuit to use.  I might also layout a PCB for it if it works as well as I think it might (I have a little more time for this kind of stuff since the start-of-semester crunch is out of the way here at OSU).
« Last Edit: October 07, 2004, 09:41:53 AM by (unknown) »
ibedonc
« Reply #4 on: October 07, 2004, 10:17:58 AM »
still available from digikey
I was looking for a charger to use in my FSW inverter , I think I will use this
the SCC3 charger I made is working good
« Last Edit: October 07, 2004, 10:17:58 AM by (unknown) »
