Hold On! We have different motors!
Mine only made a few volts in a drill. Sure sounded like the same motors (10, Hanson, 24V, 360 RPMs, size...)
If you are getting 24V in a drill, your motors are better than mine!
Connect it like a treadmill or Ametek, with a diode, and ammeter, connect it to a battery, spin it with the drill and measure the ma into the battery.
Probably be nice for 18" dia PVC blades, or maybe 'ruler blades'.
No, you were not the only one who thought they would work.
That's the same reason I bought mine.
You know, I only fully tested one, didn't try a second one because the numbers I got were so low. Maybe it was a bad motor?
