Jerry,...."the load is 2 old very tired L-16's wired 12V ".....that means their connected parallel right?....and the ammeters are connected in series with their out put,...neg of meter to neg on battery,... pos of meter to positive on battery??.....Shows how much I know,
I'm not even sure how to check for amps properly.
In searching I seen a pic of under the hood of that S-10....It looked like a bunch of big caps in there.....I'm doing experiments with caps,wish I could find some big ones like that.......sorry for the diversion.....
I assume your turbines are wired your way (Jerry Rigged)...I've a couple different drawings of how this is done, but they vary in cap placement......Would like to see how you actually do it.....I've tried several different arrangements ,...the one that gives me the best out-put isn't wired like the drawings I've seen
.....could be I'm not taking the proper readings though
I think that's enough for now.......artv
