The current solar system on my sailboat (75 watt monochrystalline panel and older morningstar PWM controller) isn't keeping up with demand, so I'd like to add additional capacity. I don't have the space to mount another rigid panel, but I've got four uni-solar amorphous (flexible) 22W panels that I could attach in various places on the cabin top. Battery bank is 240AH of wet cells, and demand is about 50 AH/day.
1) any problem mixing (in parallel) the 88 watts of amorphous panels with the 75 watt mono panel? Should I hook all the panels into a single charge controller, or would I be better off having a separate controller for each panel type? If I go with 2 separate controllers, do I just hook them up to the batteries in parallel, or will they interfere with each other? BTW- these are all 12V (nominal) panels)
2) On this size installation, is it worth upgrading to an MPPT charge controller? The boat is only 27', so I estimate my wiring runs will be 15' or less. I'm limited in the square footage available to mount panels, so an extra 10-20% more amps from mppt sounds attractive.
