Author Topic: Making an alternator  (Read 1087 times)
(unknown)
« on: January 17, 2007, 01:51:28 AM »
Ok im looking to make an alternator, so ive decided to use this one http://www.otherpower.com/pmg2.html
nowhere can i find out how to properly wire it so i would like some feedback on how to do that!
any responses would be GREATLY appreciated..
THANK you very much
« Last Edit: January 17, 2007, 01:51:28 AM by (unknown) »
asheets
Re: Making an alternator
« Reply #1 on: January 17, 2007, 10:41:43 AM »
There are several ways you can wire it up, depending on how many coils/mags you'll have.
One way is to wire all the coils in series, with 1 mag per coil.  It is the least efficient of the methods, but easiest to set up.
Another way, if you have an even number of coils, is to wire every other coil in a set in series, and run both sets in parallel.
The most efficient way to do it is to build a 3 phase (or more) setup, but you have to have the proper coil to magnet relationship.
« Last Edit: January 17, 2007, 10:41:43 AM by (unknown) »
