Author Topic: voltage regulator  (Read 3142 times)
getterdone
  • living off grid
voltage regulator
« on: June 30, 2009, 08:55:53 PM »
hey guys, in the past i ran across a web sight that offered voltage regulators to control alternators. i cant find it again. i need it to charge 24v battery bank, so i can equalize the bank safely. not being regulated i burned up a c 60 charge controller. dont want that to happen again.
thanks for help!     getterdone
« Last Edit: June 30, 2009, 08:55:53 PM by (unknown) »
  • Moderator
Re: voltage regulator
« Reply #1 on: June 30, 2009, 03:34:16 PM »
I have a feeling you will find the lost page if you Google
homepower mark8 24v
If not, you will find some creative solutions.  And some simple solutions.
« Last Edit: June 30, 2009, 03:34:16 PM by (unknown) »
« Reply #2 on: June 30, 2009, 07:52:57 PM »
When you're charging from the grid and paying by the KWH, efficiency matters, big time.  Lead-acids lose less power than NiFe.
Same applies when you're buying solar panels, of course.  But if you're mainly powering with a water wheel or a windmill and have sufficient water or wind resource it may be a better tradeoff to scale the genny up a bit and use batteries that waste more power but last virtually forever.
Fork lifts are used for things where the cash flow is so high that periodic replacement is a minor cost of business, while power density and a nearly flat discharge curve are assets and the batteries double as a small but heavy counterweight so lead is good.
« Last Edit: June 30, 2009, 07:52:57 PM by (unknown) »
(unknown)
« Reply #3 on: July 01, 2009, 06:12:03 AM »
http://www.homepower.com/files/webextras/mark8.pdf
I noticed a lot of bad links while searching. This pdf deals mainly with 12v but it may help.
Fused
« Last Edit: July 01, 2009, 06:12:03 AM by (unknown) »
getterdone
  • living off grid
« Reply #4 on: August 02, 2011, 11:00:23 AM »
OK its been a couple years now, and i still haven't got a regulator for my delco 24v 90amp alternator.
it will need to be a 3 step type.
i will be charging different sizes of battries.,600amphrs,800amphrs,1100amphrs. or altogether.
I'm not a transistor or capacitor type of guy. building it my self may not be in my scope.
I'd be willing to pay , trade , or what ever to have something that would work.
it would need to be,. self regulating. in other words, turn it on and walk away.
if your off the grid like my self. you understand the real need.
thanks to the staff and this board. with out this board my life would not be the same.
mab
« Reply #5 on: August 02, 2011, 05:58:40 PM »
Sounds like you need one of these:
http://www.sterling-power.com/products-altreg.htm
These multistage alternator regulators are popular on yachts - they allow rapid re-charge on a sailing boat where the engine's only used in the harbour - so you could look in a yachtty magazine for other makes. Trouble is, 'cos they're made for rich yachties they're not cheap.
mab
getterdone
  • living off grid
« Reply #6 on: August 02, 2011, 10:33:01 PM »
yea they are pricey. half that much would be good. but if I'm going to spend around 4grand for new batteries, and if i can't find any other solution.,or any one doesn't have a diy
solution that can show me how. then i guess pricey is what it will be. but........i think some one on this forum has the answer there are a lot of very smart people on this form.
oh and thanks for the reply.
I've been searching the net for two days and hadn't found that listing for controllers.
thanks [ getterdone]
« Reply #7 on: August 06, 2011, 10:30:04 PM »
They're pricey because they're marine rated.
You might try contacting the manufacturer and see if they have a less expensive model for a residential environment - or perhaps a working returned or refurbished unit that they can't resell as new but might sell you for substantially less than new retail.
dave ames
« Reply #8 on: August 07, 2011, 02:25:10 AM »
Hey getterdone,
This DIY circuit looks to be worth a shot..? sure beats $180 clams!
http://www.amsterdamhouseboats.nl/voltage_regulator.htm
strange coincidence with the names:
Mark8
Mark H. <-eighth letter (H)
Markkate <-email address
cheers, dave
roosaw
« Reply #9 on: August 08, 2011, 11:46:46 AM »
Try Balmar
http://www.balmar.net/
They provide DC charging solutions for boats.  I have been using the ARS-5 for a few years now and have had no problems.
Leadership must be taken, it cannot be given
