I hunted around and found some 500A rated boat/RV switches, they're claimed to be good for 36V operation, but no information on 48V.
Given they're only isolating very low voltage differences (except for the last one - assuming I'm turning them all off), I didn't consider the voltage limitation to be a problem in my application.
They cost me about $10 each - identical switches sell for anything from $6 to $50 depending on where you get them from.
I have a 200A fuse between each switch and the battery bank it isolates as some protection - 200A should just let me run the inverter and handle full load off a single battery string if the others are offline for maintenance or testing etc. The switch actuators can be removed in the "Off" position for safety.
![](https://www.fieldlines.com/proxy.php?request=http%3A%2F%2Fhouse.albury.net.au%2F13sep2010%2F100_4591.JPG&hash=c6a10676fa0615ca824cabece857776961a3d13b)
My FlexMax-80 charge controller has a seperate double-pole breaker for each array
![](https://www.fieldlines.com/proxy.php?request=http%3A%2F%2Fhouse.albury.net.au%2F23may2010%2F100_4451.JPG&hash=fc7395843df8b53b527d7ff5aec3cc80d70c4492)
and individual current metering. (Nominal 100V per array)
![](https://www.fieldlines.com/proxy.php?request=http%3A%2F%2Fhouse.albury.net.au%2F23may2010%2F100_4452.JPG&hash=8f0ace756bceebaa55d26e02e0c8d50ffec42a7b)
I've only isolated the batteries all together once since I powered the system up in 2005 - and as others have said, consideration of the sequence is important to avoid letting out magic smoke and preventing powerloss to critical services. In my case, it was:
* Disable generator automatic controls
* Power up generator
* Allow inverter to synchronise and bring generator online
* Add some "stabilising" load (around 1KW)
* Cross fingers and toes shutdown inverter (critical loads maintained on generator)
* Turn off DC input to inverter
* Isolate PV arrays
* Isolate turbine controller
* Isolate batteries
On completion of works, the steps were basically the same ones in reverse. All completed without dropping 240V AC to critical loads, and no magic smoke
![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
