"I guess what i was asking was will a 48v windmill put out a charge rate higher than 48v to charge the battery bank."
Yes. (unless you bought it on ebay! LOL)
You are (quite understandably) getting a bit lost in the terminology.
Do not take this as a terse/bad/evil/cold/mean reply... although I hear I am often terse/bad/evil/cold/mean.
Being American, I never learned to speak Austrailian. Bear with me.
![Tongue :P](https://www.fieldlines.com/Smileys/default/tongue.gif)
I would suggest reading through the FAQs.
Read them while thinking about what they are talking about.
No need to understand every word or term, as long as you can grasp the concept of the problem.
The terms will begin to fall into place.
As the terms fall into place so will the problems and solutions.
FAQs
http://fieldlines.com/board/index.php/board,27.0.htmlIn your situation, pay extra attention to:
http://fieldlines.com/board/index.php/topic,143908.0.htmlhttp://fieldlines.com/board/index.php/topic,143642.0.htmlhttp://fieldlines.com/board/index.php/topic,143574.0.htmland
http://fieldlines.com/board/index.php/topic,143592.0.html(if someone smart and honest has tried 8463 different wiring methods and determined how your version of an F&P should be wired for 48V with a certain type of blades, believe them!)
and do not make the newbie mistake of believing high open circuit voltage means high power output.
I fell for it, wasted a lot of time and money, and I know better now.
Here is a terminology glossary.
If you only speak Aussie, it will help about as much as a Greek to Latin dictionary.
I hope it will help as you read through the FAQs.
http://fieldlines.com/board/index.php/topic,144541.0.htmlECM is electrically similar to F&P.
One is insideout from the other. The concepts are the same.
