Hey guys.
I've done some reading here and on other boards, but haven't found the "definitive" answers...
I like the idea of using a low- or no-cost discarded UPS as an inverter. My plan would be to add cooling/sinks and use it with a ~500AH 12v deep cycle battery bank. Working load would be ~300watt, with occasional peaks to 800ish.
I see lots of talk about super cheap or free UPS discards, but I'm not finding them myself. I looked on ebay - mostly pricey with exhorbitant shipping costs. Where are you guys finding the deals?
Is there such an animal as a 3000VA UPS that will make 110vAC from 12vDC battery bank? Model recommendation?
What is the solution to the high UPS STBY current? Are certain models better than others in terms of lower stby current? Did anyone ever come up with a PIC circuit design for effective load sensing? Can the stby load be reduced by disabling certain UPS functions?
Are UPS's pure sine wave or MSW? Or does it vary from model to model?
What about 220vAC to allow sporadic use of my 220V 0.5HP 400watt (650 peak) water well? Is there such an animal as a 220v UPS with 12v batteries? 24v batteries? 48V?
Lastly, a general design question: Assume a sub-panel with two 15A 110v breakers plus one 220v breaker for the water well. The water well only comes on a few times per day to fill a pressure tank. The 110v loads are intermittent: lighting, computer, internet. If I use either a 220v inverter, or a 110v inverter plus a 1:2 step-up transformer, to push 220v at the panel, is it acceptable to run a few 110v loads from the panel while the well is not in use? IOW - the 110v loads would only be using one leg of the "220v supply". Is this kosher, or disastrous, or
![Huh? ???](https://www.fieldlines.com/Smileys/default/huh.gif)
I know...lot's of questions! But hey - I'm searching for knowledge!
![Grin ;D](https://www.fieldlines.com/Smileys/default/grin.gif)
Thanks!
