It's been just over five years since I last posted on this board. WOW! How things have changed and how the site has grown! Congratulations to the Dans, and greetings to Charged, Old F, Ungrounded Lightning Rod, Rob D (if you're still out there), Tom W and to all you who have joined along the way.
I thought I would post some pictures of the little tiny prop that I have carved for my little model wind generator. I live in the city, so there is not much A/E opportunity for me these days I'm afraid, so I am somewhat relegated to what I can fit in my back yard.
Thus, my mini-mill sits on an old camera tri-pod with the new 60cm 2 blade prop installed on it that I recently finished fiddling with over my vacation. It's tricky to get time and $$$ for things like this with 2 little ones and a full time office job, but I hope some of you will enjoy the photo diary I'll be posting here to show the process as I went along.
I've always liked pictures, so let me try to post a few... Let's start with Step 1: Drawing the guide lines, evenly spaced on the 2" X 4" that I started with...
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=921;image)
Basically, I drew on the "stations" and used the spreadsheet downloadable from ScoraigWind (Hugh Piggott's site) to mark out the "width" dots. Then I connected the dots with curves in order to get the rough wing shape.
Next, I used a jig-saw to cut out the rough shape...
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=922;image)
Then I re-drew the guidelines onto the area that I had cut away, and took the measurements from the spreadsheet to draw the "drop" dots, and connected them with a curving line.
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=923;image)
Next, I used a drawknife to rough out the drop on the front face of the blades. If you don't have a draw knife, GET ONE. They're fantastic to work with. I got mine as a birthday gift from my Dad from Lee Valley Tools.
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=924;image)
Okay, next, I used my stationary belt sander to smooth out the deep scoop near the root. I got a little over ambitious (and lack skill - to say the least, as I've never really used the thing for much, being an "office dude") and it went a little deeper and a little less evenly than I would have liked, but hey, how else am I going to learn?
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=925;image)
I then marked the "thickness" of the blade from the measurements from the spreadsheet, marked them out and carved out the back side of the blade. I had to jump ahead a few pictures here as I can only put 10 in a post. Suffice to say, I used the drawknife for the roughing out and the belt sander again for the smoothing and levelling of the blades. I then drew the "Thickest Point" dots on the back faces of the blades by using 35% of the overall width at each station. I connected those dots to get a line to show me the thickest part of the wing shape in the currently flat blades...
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=926;image)
I then carved the triangular wing shape by carving down everything from the thickest point on the back of the blades to the leading edge of the face and from the trailing edge of the face to the thickest point for each of the two blades. I then used my smaller stationary sander to sand off the triangular "thickest point" and round it to the wing shape. It's tricky to see in this shot, but you get the sense of the wing shape.
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=927;image)
Here you can see the final sanded blade...
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=928;image)
And here it is on the model...
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=929;image)
Last Pic. Here you can see the 2 LED lights that I attached in reversing directions from one another. When the electricity goes through 1 way, the RED LED lights up, and when the electricity goes the other way, the GREEN LED lights up. It's a great visual way to explain Alternating Current to the kids, as long as you explain that LED's are like a one way valve for electricity. It clearly shows how the polarity in the alternator is forever going back and forth, to create alternating current.
![My Mini Prop for my Mini Mill](https://www.fieldlines.com/index.php?PHPSESSID=d4cb64a3465e79854e91feb72d9246bf&action=dlattach;topic=144016.0;attach=930;image)
I still need to touch up the balance on the blade as it was a little off after I painted it. Still, it spins up easily and it is faster than the former 3 blader I had on there (until I tipped it over when moving the tri-pod and BROKE one of the blades - ugh). I have a small diode bridge in there to allow it to charge up to 4 "AA" batteries.
I got the bearings and shafts out of scrap printers that repair technicians gave to me. (I work for Xerox, so as long as I can stay chummy with some repair guys, I should be able to get plenty of those!)
It has been a fun project. Thanks for letting me share it with you folks.
Regards,
Xeroid.
