Author Topic: Inverter/charger  (Read 1158 times)
arbela47000
Inverter/charger
« on: September 28, 2008, 04:44:07 AM »
It seems to me that the last time I looked at home power equipment, there were inverters and charge controllers.  Now, I see things that are called "inverter/chargers"  Example: http://www.infinigi.com/xantrex-8651000-xw604812024060-6000w-24vdc-xw-series-hybrid-invertercharger-
p-2347.html?ref=100
Does anyone know anything about these?  Are they simply combinations of inverters and charge controllers, or are they something more?  If one wants MPPT charging, does one need to buy a separate MPPT charge controller, or do these things have one built in?
I couldn't find any posts about this elsewhere, so please forgive me if I'm the thousandth person who's asked these questions.
« Last Edit: September 28, 2008, 04:44:07 AM by (unknown) »
Re: Inverter/charger
« Reply #1 on: September 27, 2008, 11:12:22 PM »
You would still need a charge controller for your solar array with that. Solar>MPPT>batteries/genset>Xantrex>grid/home.
A forklift battery with that would be sweet. 6kw is more than enough to run a home. The "sale" ends today.
« Last Edit: September 27, 2008, 11:12:22 PM by (unknown) »
(unknown)
« Reply #2 on: September 28, 2008, 09:07:21 AM »
What you are referring to is an inverter that has a 120 volt AC battery charger and transfer switch built in, for charging from a generator or the grid. Easy for them to incorporate into the circuitry. When you start your generator, the inverter automatically switches all your loads over to external power. You'll still need a separate controller for any PV or wind you have.
ADMIN
« Last Edit: September 28, 2008, 09:07:21 AM by (unknown) »
arbela47000
« Reply #3 on: September 28, 2008, 11:13:26 AM »
I know that 6kW is overpowered for a home, but I'll be powering a walk-in cooler and a woodworking shop off this inverter, too.
TO both dnix71 and ADMIN, thanks for the clarification on the technical setup with this piece of equipment.
« Last Edit: September 28, 2008, 11:13:26 AM by (unknown) »
scottsAI
« Reply #4 on: September 28, 2008, 11:58:40 AM »
Arbela47000,
On sale or not, do not make a rush decision until you understand what you need and want.
If I buy something and they tell me its a one time offer I stop talking immediately.
Others have same unit for little more so sale term is relative.
Spending this kind of money should be a big decision, time invested can have big payback in getting just the right thing for your situation. Waiting for the next sale may be worthing while learning about it.
Many options out there, unless we understand what your goals are we can't help you very well. Have solar, grid tied, wind, hydro, need load dump, tracker etc?
All too often people decide they want something. Then they post asking if what they did was good??
Does not compute. Ask first has much better outcome for you.
Have fun,
Scott.
« Last Edit: September 28, 2008, 11:58:40 AM by (unknown) »
« Reply #5 on: September 28, 2008, 01:31:49 PM »
Agreed, when buying equipment, you should know what you are buying before you buy it if at all possible to avoid expensive mistakes.  Many of us have learned this from experience.  Rich
« Last Edit: September 28, 2008, 01:31:49 PM by (unknown) »
arbela47000
« Reply #6 on: September 28, 2008, 06:55:07 PM »
Well, I wasn't too concerned about the sale price expiring; I won't be building this system for about 3 years.  I plan to put in Uni-solar shingles or laminate strips for a total of around 3 kW.  If I have an inexpensive (self-made) turbine or several that can take up some of the load, I can likely size down my solar generation capacity and save a bit of money on the production side of things.  I plan to use a powerful inverter so that I have the surge and operating capacity to run a walk-in cooler.  I plan to run with about 150 kW of battery storage for a couple of reasons: 1)the walk-in cooler; 2)the climate where I'll be moving is one I know pretty well, and it can get pretty cloudy there for extended periods.  The longest cloudy/rainy spell I saw up there was about 28 days.  I figure a lot of battery power will be needed to last through that, although wind power would help alleviate some of that concern.
Here are the things I don't know about my system:
  1. I don't have a specific site picked out, although I have my eye on one or two.  I may find a fantastic micro-hydropower site, in which case all of this concern about wind, panels and batteries will be a moot point.
  2. I don't know if I'll be grid-tied or not.  If so, I'll cut down on batteries and save a good deal of money.  Additionally, I'll probably make a whole bunch of devices to produce power and sell it back onto the grid.  If not, I'll need to make a dummy load (like a pond heater) to take up the excess load when the batteries are full.
  3. I don't know what charge controller would be best, so any suggestions would be welcome.  I'll probably run either a 24 or 48V system, if that helps.  What exactly does maximum power point tracking mean, and how much better (or worse) is that than non-MPPT?
I don't plan to do anything without plenty of research and conversations with people (hence why I've signed up for this site three years before I'll need to use the information).  I may build some proof-of-concept models to make sure that I understand everything, but the real deal is still in the future.
Sorry this was so long, but you did ask for details. :)  Thanks in advance for any advice/thoughts you care to share.
« Last Edit: September 28, 2008, 06:55:07 PM by (unknown) »
scottsAI
« Reply #7 on: September 28, 2008, 08:12:11 PM »
Arbela47000,
I would rate that answer as just right!
Cool.
I designed a 8x8 foot freezer using parts from a chest freezer.
Have not built it, someone else was interested.
Wife doesn't like my projects, so have stayed away from building much beyond a whole house UPS to keep essentials going for couple days.
MPPT is maximum power point transfer.
Electronics to match a solar panels output to a battery.
Solar panes are rated at some ideal voltage and current to make rating of panel.
Example for a 34 watt panels is17v at 2 amps. (easy numbers)
If connected directly to 12v battery, you get 13x2 or 26w of usable power.
Much less than the rating of the solar panel.
MPPT controller will boost usable power up to maybe 32watts.
Depending on you planetary location the benefits of MPPT can vary just like a tracker.
Here in MI, claim is around 25% boost in power using MPPT and 29% tracking.
Both if done DIY are cost effective, cost determines whether its worth doing.
Have fun,
Scott.
« Last Edit: September 28, 2008, 08:12:11 PM by (unknown) »
arbela47000
« Reply #8 on: September 29, 2008, 04:32:14 AM »
Okay, so I did the math to figure out what size charge controller I needed, and then noticed that the only MPPT charge controllers I could find that would run a 48VDC battery system were the OutBack ones.  Only problem is that the spec sheet for those controllers says: "Consult factory for approved hydro/wind turbines."  Do you know of any problems that might arise with turbines that would fry a controller?  I tried to find a post that talked about such things, but came up with nothing.
If I would be better served by posting this question in the wind section, I'll ask over there instead.  Thanks.
« Last Edit: September 29, 2008, 04:32:14 AM by (unknown) »
