Bob,
I am ploding along on a duel rotor microwave magnet jobie, some tests done last Sunday but not happy with accurcy of data yet. Will try again tomorow.
I used 12 magnets doubled up on each rotor, of course the air gap is critical, here is where I have to do more testing and data logging.
At one stage I had one coil 80 turns of 0.5 mm wire loaded with a 12 volt down light (0.6 ohm cold) and had 2.18A at 3.7V driven by my 2 speed metabo drill on low speed. Now i'm guessing the speed was 750 rpm. Like I say much more testing required, but has some prommis but will be very heavy.
Open circuit volts 16.8 AC Air gap was 17mm at this stage I think, my note book looks like the chooks scratched on it.
My origional aim was 6 phases 12 coils in series, that would be positivly packing the stator full. The coil ends would be overlapped in the relativly large space above and below the ring of magnets. My origional theoretical idea was 12 coils of 1mm in series at 40T achieving a max of 5A/phase, I wont put too much data here best to have ppl think I'm a fool without confirming it.
I agree with the other response your idea of another ring could work if seperatly rectified for the reasons given. What weight is your setup as is?
Allan in WA
