Author Topic: F&P Floating Hub - Part II  (Read 1179 times)
domwild
« on: January 26, 2005, 06:40:11 AM »
This shorter photo shows one of two pillow block bearings on the left. I am using two pillow block bearings as I do not trust the washing machine bearing too much. It is only used to centre the stator within the rotor.
The bolt on the floating hub attaches the stainless steel bar which holds the prop. The smaller flange is attached to the alternator shaft by means of eight M6 grub screws, which bite into the spline shaft. M6 ~ 1/4".
Rather than having one bolt on the prop flange then hit a bolt on the alternator flange I am thinking of a spring loaded flat bar being hit by the bolt on the prop flange. Once the spring expands it should (hope, hope) turn the cogging alternator.
« Last Edit: January 26, 2005, 06:40:11 AM by (unknown) »
Re: F&P Floating Hub - Part II
« Reply #1 on: January 26, 2005, 05:46:50 AM »
  Probably pretty good now if you would have
edited the picture to about 640 x 480 instead of
1638 x 1229, I mean you took the time to white
out irrelevant parts of the pic just a little
more time toward reducing the size before you
upload ......I've seen this excuse posted before
It looked fine on my browser/monitor/
screen, so I assumed it would be okay on everybodys
   There's that word assume and you know what
 they say about that.....
                  Norm.
« Last Edit: January 26, 2005, 05:46:50 AM by Norm »
John II
« Reply #2 on: January 26, 2005, 04:49:23 PM »
Great looking hub domwild ! Please keep all of us posted on your project as you continue... It looks quite interesting.
Hey Norm.... have you considered getting a little larger monitor then that little one you have been using ?
John II
« Last Edit: January 26, 2005, 04:49:23 PM by John II »
domwild
« Reply #3 on: January 26, 2005, 08:51:41 PM »
My apologies, being a newbie and a mere lecturer in IT who knows more about 8086 assembler and operating systems, but nothing about photos. Have managed to reduce the size in kb and now found out with new photo software how to reduce the image size, too. It will not happen again.
« Last Edit: January 26, 2005, 08:51:41 PM by domwild »
free energy64
« Reply #4 on: February 07, 2005, 12:55:05 PM »
Can't seem to see your pic. Am very interested in the idea. Please re-submit picture.
« Last Edit: February 07, 2005, 12:55:05 PM by free energy64 »
