I have inherited two PV arrays and one charge controller. I am hoping to describe to you the system, and would love to hear your comments about if it can be set up in a better way to make the most of the power it generates.
The system is 24V. There are two arrays (racks) One rack has a number of 12 volt panels that run in parallel to make each pair of two 24V. Each set of two panels runs in to one BlueSky Fuse box that leads to the ONE charge controller. This allows each 24V panel to be isolated from teh others.
The second rack has a series of 24V panels of different wattages running down in to another BlueSky junction box with fuses that also leads to the ONE charge controller.
Yes, I know this is not a proper set-up, but it is what i have to start with. ![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
The charge controller is a RVProducts Solar Boost 50 with MPPT. (up to 20 amps.)
Array one has two 12V 64W panels, two 12v 130W panels and four 53W panels.
Array two has four 24V 160W panels and two 24V 150W panels.
As stated above each array is merged in a fuse box and sent to the charge controller where the two separate copper lines are connected (to each other) at the box.
My first question is simple: Does having the panels set up this way make my wattage decrease down to the lowest common panel in the system? AKA: Am I throwing away power?
Next if so, is there a better way to set this system up? For example, do I get a second charge controller and isolate the two arrays each in to their own charge controller? Or is there a better way to maximize power?
Thanks for your guidance on this folks.
