Author Topic: Giant 4ft fresnel lens, $50  (Read 1579 times)
wbeaty
« on: August 18, 2004, 06:47:31 PM »
Here's something interesting I just saw in a sales flyer:
  Giant 31" x 40" Flexible Fresnel Lens - G13994
http://sales.goldmine-elec.com/prodinfo.asp?prodid=9039
DOesn't give the focal length though.  I saw someone at the Seattle UW street fair
using something similar to make jewelery; melting various colored glass
rods with sunlight to make "raindrop" shaped earrings.
DON'T leave such a large lens indoors without covering it.  If a sunbeam
should hit it wrong, even the reflection from the grooves can start a
fire.
Something that does work:  solar-powered wood burner.  Get a metal-jacketed
fiber optic bundle (glass fibers, not plastic, sometimes these show up in
surplus catalogs.)   Stick one end at the focus, use the other end to
write your initials on a 2x4.   But the end of the light-pipe at the focus
gets cookin.   Probably needs a metal block with water cooling if you want
to do it right.
The same catalog also has 400nM UV LEDs for $0.99.  For Burning Man, cover
your body with tattoos of tavern-rubberstamp invisible ink, then wear an
ultraviolet tiara?  (Or buy those expensive UV-fluorescing contact lenses,
for Blinking Alien Eyes effect.)
http://sales.goldmine-elec.com/prodinfo.asp?prodid=7291
« Last Edit: August 18, 2004, 06:47:31 PM by (unknown) »
Nando
Re: Giant 4ft fresnel lens, $50
« Reply #1 on: August 18, 2004, 08:58:19 PM »
Well I have one of those, that I bought during Hamcom in Arlington Texas this past June for 5 dollars.
These Fresnel lenses are used in projection TVs.
At the moment I do not remember the focal point but one can calculate the energy if you assume 750 watts per square meter concentrated to 10 mm^2 to 100 mm^2 ( 10 to 100 square millimeters )
In July summer, noon time, I melted 3 onces of solder in about 30 or 40 seconds.
Regards
Nando
« Last Edit: August 18, 2004, 08:58:19 PM by Nando »
