As far as I know 100% PFC correction doesn't cost you less.
Here, where I live, we don't get billed in VA we get billed in watts. Only industrial users get billed in VA, that is actual, measured, Volts times Amps. So, when you have something, like say a fridge, and it's compressor is running at 33% efficient PFC you are only paying for a 1/3 of the amount of power you are effectively using. The advantage of using an appliance with 100% PFC correction is that there are less harmonics in the electrical system, however, you end up paying more to use the device than if you didn't correct it.
HTH
