Hi Scott,
You'll need batteries and an inverter to convert the power to 110v (or whatever your local voltage is) and then, yes it's a good question, how to you use it? If you don't use it, you're wasting electricity as surely as if you left the lights on... (And burning fossil fuel or whatever at your power station when you didn't need to.)
At best, my mill only supplies about a tenth the electricity that we use.
I have a fairly simple system for my green power: the batteries and inverter are in the garage. I run an extension cord through a hole into the basement, across the length of the house, and then up into the sun room where we spend most of our time. From there, I can plug in whatever will match the amount of power I'm making. In the Summer, it's not much but it was enough to power some lights. In the Fall, it was enough to power the TV. (The mill tower didn't survive into Winter so I'm not sure yet what the windy season would have powered.)
I do have a "transfer switch" (google that) that will route the about a quarter of our house wiring to our backup generator but I'm not making enough wind power to plug into that (yet!) ...
You'll need to see how much wind energy your really have. The answer will not only vary by season but also by weather conditions from day to day... because of that, you'll need some method to be flexible with what you plug in.
Hope that helps,
- Ed.
