| There's nothing really unconventional about it - it's a simple 12 pole, 9 coil generator wound with 44 turns of AWG 14 wire, two-in-hand. At lower outputs, under 15 mph wind speed it groans so loud you can hear it from a considerable distance and it makes the tower "buzz" - you can feel the vibration in the tower.
As it picks up speed it quiets down some but the groan changes to more of a whistle or a high-pitched moan. I used to have an 18 coil generator in this turbine with 12 poles and I uploaded a picture of that stator taken when I was winding it:
The 18 coil stator, although the phase timing was off with 12 poles, was one of the smoothest running generators I've ever seen. But wound with only a single strand of AWG 14 the smoke escaped out of it one day in high wind. That smoke was what made it work, because after that leaked out it was done.
Back to the noisy nine coil - this thing vibrates so bad I had problems with the stator bolts coming loose. I finally used stainless steel locknuts and those have stayed tight. The stator makes tremendous power - I had it hit 2.0 kW once when I discovered my furling calculations were bogus, and it didn't hurt the stator. I took a picture of the turbine when it was spinning at almost 900 rpm that afternoon (which I think I posted here once) and I should've taken a movie of it so you could understand the noise - at that speed it was actually making a howling noise.
I don't know what I did wrong in that stator but I know I don't have any coils backwards in it and I know all the phases are wired right because the output between legs is dead even between any pair.
I got a 16 pole 12 coil in my 10.8 footer and that's a sweet running generator - it's as smooth as the old 18 coil stator used to be in this one. I just wish I could come up with a way to make this 9 coil run smoother.
Chris |
133 Scoop users have viewed this posting.
