I have an Ametek '30' on my Pedal Generator,
34 inch diameter crank flywheel .....2inch dia.
motor 1:17 ratio,with a full wave rectifier.
Charging 2 12volt batteries in series I can pedal
with ease like pedaling a bicycle on a level
stretch 60rpm crank speed 1020 rpm motor.....60
watts. This is where reality sinks in ....to
charge a 12volt battery at this ratio is difficult
because it kicks in at a lower speed....I'd guess
520 rpm and about 30 watts to a 12 volt battery.
Never tried it on a windmill yet.
A rope wrapped around the shaft the generator
hooked up to a battery thru a rectifier...a
a tachometer a couple of milk jugs on the end
of the rope, a fairly simple exercise in math
will give you all the data you need to know,
then you can give us your data....and we can
compare notes....
111 Scoop users have viewed this posting.
