I'm not able to post a reply (continued)
By egreen, Section Wind
Posted on Tue Nov 03, 2009 at 02:53:53 PM MST
A little help...
I ran the Fieldlines.com 'Reply to This' page through the an HTML validator (http://validator.w3.org/).  There are quite a few markup errors on that page.  There are some tags that are not closed.  There is one place where the 'FORM' close tag is not found and then there is another place where the end '/FORM' tag is found without an open 'FORM' tag.  This is probably what is causing the problem with IE not being able to 'Preview' or 'Post' a reply.  Firefox and some other browsers may just ignore the errors or parse the page in a way that avoids the error.
I'm not able to post a reply (continued) | 5 comments (5 topical)
Re: I'm not able to post a reply (continued) (3.00 / 0) (#1)
by hiker on Tue Nov 03, 2009 at 05:56:47 PM MST
test
WILD IN ALASKA
Re: I'm not able to post a reply (continued) (3.00 / 0) (#2)
by ubud on Wed Nov 04, 2009 at 08:39:08 AM MST
I,ve not had any problems,
imac using firefox
Frank
CIWIH (cause its what i had)
Re: I'm not able to post a reply (continued) (3.00 / 0) (#3)
by bzrqmy on Wed Nov 04, 2009 at 03:45:35 PM MST
Well,  I just installed Firefox because I could not post with IE8.  Appears to be an IE8 Problem.
Re: I'm not able to post a reply (continued) (3.00 / 0) (#4)
by gizmo on Wed Nov 04, 2009 at 08:08:08 PM MST
Its not a IE problem, its a problem with the fieldlines forum software, IE is working perfectly. IE is just doing whats its supposed to do and not processing a page with a broken form. Chances are a future update to Firefox will cause it to behave in the same way as IE is now.
I'm sure the administrators are aware of the problem and working on a fix as we speak  :)
Glenn
http://www.thebackshed.com
Re: I'm not able to post a reply (continued) (3.00 / 0) (#5)
by Tink on Fri Nov 06, 2009 at 07:06:07 AM MST
I just downloaded Firefox and now I can do everything here. But maneuvering around the forum is slow and i haven't figured how to get to my Hotmail account yet. At least I can post here and Firefox seams to be much faster at other sites. The spell checker with Firefox is a real plus. I think one of those recent updates from MS was to IE8 because I wasn't running IE8 a few days ago when all was fine.
for what it is worth...
Tink
  57 Scoop users have viewed this posting.
· http://val idator.w3.org/
· Also by egreen
