doubling coil thickness
By ejl7007, Section Newbies
Posted on Mon Nov 02, 2009 at 09:51:02 PM MST
how will the flux change should I thicken my coils and space my rotors further apart.
Hey guys...my experiments have run perfectly thus far.  I have been experimenting with a stator that is 3/4" thick nestled between two steel rotors at 1/8" apart.  I am getting a lot of power, but I was wondering what would happen should I decide to cast another stator that is twice as thick.  Currently I have 12 coils each wound with three strands of awg #14 magnet wire at 45 turns each.  The rotors have 16 neos each at 1" thick.  If I wound coils that were twice as thick, i.e. 90 turns that fit in a stator that was 1 1/2" thick and placed it between the two rotors and kept the gap at 1/8" what would happen?  Would I double the voltage? Or due to the fact that the rotors are 3/4" further apart from each other would I lose some power...I understand that the closer the rotors are kept together the stronger the attraction of the magnets, the stronger the emf and so on...and vice versa...Would you recomend that I get thicker magnets instead? i.e. 2" thick?  I thought that the stator should always be about the same thickness or less than the thickness of the mags...I apologize for any rambling, but I am most curious...
Sincerely
EJL
doubling coil thickness | 3 comments (3 topical)
Re: doubling coil thickness (3.00 / 0) (#1)
by Flux on Tue Nov 03, 2009 at 12:24:25 AM MST
With a 3/4" thick stator you are near optimum with those magnets. You can vary the thickness either way quite a bit with little difference in power out.
If you double the thickness you can get in twice as many turns but your flux density will be just about halved so the voltage will be very similar.
Your 1/8" clearance between magnets and stator is costing you a fair bit but with an alternator that size you most likely can't reduce it a great deal and still be safe mechanically.
With thin stators you have a high gap flux but little winding space and the 1/4" mechanical gap is a large and wasteful factor in this winding space.
With wide gaps this mechanical gap is less of an issue and within reason it pays to use a lower flux and have more winding space. There comes a time with large gaps when the leakage between poles becomes excessive and that limits the stator thickness.
As far as the magnets go it is best to work them half way up the demagnetising quadrant and for typical neo you are looking at something around 600 to 650 mT.
This occurs when the air gap is the same as total magnet thickness if you ignore flux leakage. For 1" thick magnets it suggests an air gap of 2 ". In real life it works better at something like 1.5" and with narrow magnets you may be better off with something nearer 1.25". Leaving 1/8 per side for clearance this makes your best stator thickness something like 1".
I think with careful optimising you will do a little better with this than a 3/4" thick stator but it's not going to be an improvement that's going to change the world so what you have now is not going to be far away from the ideal.
Just as the force varies as the inverse square of the distance between magnets, the flux varies as the inverse over a fair range so big gaps low flux, small gaps high flux. For a given set of magnets you have a fixed power out at a given speed and not much you can do to alter it.
Re: doubling coil thickness (3.00 / 0) (#2)
by gizmoguy on Tue Nov 03, 2009 at 06:14:54 AM MST
Wow Flux...I am impressed.  Where do you guys learn all of this stuff?  Thanks again for helping us to better understand theses machines!
-Gizmoguy
Re: doubling coil thickness (3.00 / 0) (#3)
by fabricator on Tue Nov 03, 2009 at 04:24:17 PM MST
Great Jumping Jehosephat! That is so far beyond me it might as well be in another galaxy.
I aint skeered a nuthin......Oh S%*T! What was that?!!!
  118 Scoop users have viewed this posting.
· Also by ejl7007
