| Current turbine stats: 5.5ft 3 wood blade HAWT, dual 8" rotors, 16 neo magnets (2" x 0.5" x 0.5") per rotor, 12 coils (3 phase, 4 coils per phase, #16 wire, 72 turns/coil).
My current stator is a little bit larger than 0.75" thick because of the 72 turns of #16 wire per coil and the small 8" rotors. Each coil produces about 1.6vac (stator is 12vdc). Because of the small diameter of the rotors and the thickness of the wire I made the coil centers so that they were slightly smaller than the dimensions of the face of the magnets.
I came across a spool of #22 magnet wire so I began testing some coils for a new thinner stator. Because of the existing coils, I figured that I'd need at least 72 turns to get the 1.6vac out of the coil. However because the wire is much thinner I was able to make the center of the coil quite a bit larger than the size of the magnets and I was also able to close the air gap from 1" to just about 0.5625". Turns out that with the new coil dimensions and the smaller gap the 72 turns of #22 produced close to 2.9vac. What is going on here? At 2.9vac I could go 24vdc instead of 12vdc (2.9 x 4 x 1.73 x 1.4) - 1.5 = 26.6vdc. With another #22 coil having the same dimensions and at 45 turns instead of 72 turns I get the same 1.6vac that I got from the #16 coil with 72 turns and a smaller center. Is the size of the center of the coil making the difference? The smaller gap should only result in more current not more voltage, correct?
The RPM that I ran the tests were always between 220rpm and 230rpm. I have a digital tachometer so I know that speeds are consistent between coil tests.
How much current can I safely put through the #22 wire if I pot the stator using poly resin and talc? I put 6amps of current through the coil and it became VERY hot after about 1 minute. Almost too hot to pick up. I'm just not sure how hot is too hot for a coil cast in resin. |
