| hello all-
i'm nearing completion of my wind turbine and have 400 w worth of solar i'd like to install all of this up at my ranch. the place is off the east flanks of mt. adams. 4,000 ft above sea level. in the summer it can get above 100 degrees F, and in the winter can get well below zero degrees F.
i realize this will play major havoc on my battery bank.
here's the plan:
create a battery box that is inslulated with rigid polyisuciornate scraps i have. include a small vent on the top to let out charging gasses.
install a HVAC heat/cool thermostat.
set the heating @ 40 degrees and connect a 100w incandecent light bulb (via relay or something) to keep the batterries from freezing in the winter.
set the cooling to 80-90 degrees. two computer fans would be connected to this circuit. they would atach to a long underground run of 3 inch abs/pvc pipe that created a loop. one fan would push air from the battery box into the pipe, and the other would pull air back out the other end of the closed loop. both ends of pipe would terminate within the battery box with fans on the ends. basically a ghetto geo-thermal set-up.
my place is un-attended for up to a few months at a time, i don't want the batteries to have to fend for themselves. plus using wattage out of the bank to heat/cool is no big deal since it would be dumped anyways when no-one is up there.
another thought... i could put the dump load in the battery box to keep it warm in the winter, but would rather put it in the shed to melt snow off the roof, and keep paint/caulking from freezing over the winter.
okay, so poke a million holes in my theory! really!
i want to do this right the first time!
thank you for ANY replies!
birdhouse |
72 Scoop users have viewed this posting.
