to solve low water problem
By bgarrett, Section Hydro
Posted on Wed Oct 28, 2009 at 09:03:46 PM MST
what to do?
My creek has a great flow most of the year but slows to very little in August.
It doesnt seem like a good idea to put batteries by the creek if they will not get any charge for a month or so.
 my building will be about 250 feet from the creek and the batteries should close to my point of use, right?
Is it possible to generate at 120 volts so the power can be sent about 250 feet then converted to  12 volts to charge my batteries?
to solve low water problem | 8 comments (8 topical)
Re: to solve low water problem (3.00 / 0) (#1)
by Ungrounded Lightning Rod on Wed Oct 28, 2009 at 09:29:02 PM MST
Yes.
Re: to solve low water problem (3.00 / 0) (#2)
by bgarrett on Wed Oct 28, 2009 at 09:59:41 PM MST
Great! Can you suggest a hydro generator?
Re: to solve low water problem (3.00 / 0) (#3)
by chainsaw on Thu Oct 29, 2009 at 04:56:08 AM MST
 You need to know water head and flow in gal per minute to determine your potential output. Then look at units that meet those parameters.
Re: to solve low water problem (3.00 / 0) (#4)
by bgarrett on Mon Nov 16, 2009 at 10:21:32 PM MST
All the hydro generators I find on the internet at DC
Can you point me in the direction of 120 volt Alternating Current hydro generators?
My dam is about 600 feet from the house where the battery bank will be
Re: to solve low water problem (3.00 / 0) (#5)
by ghurd on Wed Nov 18, 2009 at 08:28:06 AM MST
Lots of alternators, probably most, will make 120VAC.
Unless you mean 120VAC 60HZ single phase, then you are out of luck without a lot more research.  And the more you research it, the more you will find you are pretty much out of luck.
Most decent DC generators are actually 3-ph AC alternators, intended to be rectified to DC output.
So far the only thing we know is it is hydro, without enough water sometimes, 250' or 600' (?), and 12V batteries.
Without the head, flow, type of water wheel, etc, etc, etc,
nobody can point you toward anything relevant.
Re: to solve low water problem (3.00 / 0) (#6)
by bgarrett on Wed Nov 18, 2009 at 01:46:58 PM MST
there is no reason for you to be rude
Re: to solve low water problem (3.00 / 0) (#7)
by ghurd on Wed Nov 18, 2009 at 03:10:32 PM MST
Correct.
Where exactly was I rude?
In my garage or basement I have:
A few 2" square stepper motors that will make 120VAC,
Several baseball sized 3-ph motors that will make 120VAC,
More than a few mid-sized AC conversions that will make 120VAC.
And a 80(?) pound Leeson that will make 120V.
Send me $250 and I'll send you an alternator than makes 120VAC.
Is that what you are looking for?
Because that's what you are asking for.
Re: to solve low water problem (3.00 / 0) (#8)
by TomW on Thu Nov 19, 2009 at 03:59:23 AM MST
bgarret;
If you think that was rude, you need to grow a thicker hide before jumping into the internet.
Seriously, lighten up.
I thought he was very accurate and honest about our inability to reply with useful information to your vague post.
You are welcome!
Without fools, you could not look intelligent. There is no knowledge without questions.
  94 Scoop users have viewed this posting.
· Also by bgarrett
