ok, I want to replace the 1500 watt submersible heater that I have to use to keep the horse trough from freezing. Seems this is a great place to use ground heat, since I'm just aiming for "not frozen", rather than "room temperature".
We pay about $0.09/kwh, so a 1500 watt heater, that bareley keeps up when it's really cold and/or windy, costs me about 13.5 cents per hour to run, or in a 24 hour day could cost around $3.25 per day. A month of really cold weather can really start to add up.
I need to rent a trencher for another project anyway. I'm told it will go down about 5 1/2 feet. I'm looking at burying tubing, recirculating it through the trough. It appears that 100w pump can transfer as much heat into the tank as a 1500 watt heater.
The numbers I have at this point:
2 gallons per min, 5 degree F delta T -----> 1408 watts
linear with respect to both gpm and delta T.
I think I'll need to insulate the tubing from around the frost line up to the tank. The question I have are:
Will black ABS tubing work? I assume copper would be much better for the heat transfer, but how much better? and it is worth the $, when I could use twice as long a run of ABS for less than the same $.
Also, I assume more surface area is better. Should I consider 2 parallel runs of 1/2" tubing, as opposed to, for example, a single run of 3/4" ?
Rather than trial-and-error my way through this are there any recommendations for tubing size, length, flow rate, etc?
Thanks in advance,
Dan M |
87 Scoop users have viewed this posting.
