Hi Neil,
We experimented with a few different epoxies and techniques, though I could see where more thorough testing could get expensive.
We selected this one; the Durapot 865:
http://cotronics.com/vo/cotr/pdf/860.pdfNote, I discovered an inconsistency between the thermal conductivity rating on this pdf (12), and the catalog (20). I confirmed with the manuf. that 20 is correct (Btu in/hr. degF ft^2)
The biggest trade-offs seem to be that the best epoxies
thermally tend to be thicker - 5 to 15 times thicker in some cases. You can add a thinner, up to about 5% reportedly, before it starts to impact maximum service temperature and strength. We used 3%. The other 'trick' the manufacturer suggested was to heat the mold and coil slightly, and keep the resin & hardener at least at room temperature. This seemed to make a big difference in how well it flowed and filled the smaller voids.
The other trade off was that ultimately I decided against using mesh (which I'd purchased and cut), or chopped strand. The concern was that anything gained in strength might be more than offset if we didn't get thorough penetration or had voids, particularly in the T &G area.
The post cure reportedly improves thermal properties, chemical resistance and strength. The latter is pretty self-evident between the 'green' material fresh out of the mold and the post-cured sector.
Regarding the loss of winding space, Flux has it pretty well covered. The T& G is about 3/16". The coils are wound such that they are tight at narrowest spot between adjacent coils.
From the outset we've been designing around using MPPT (with contributions from folks here). Our alternator is somewhat overbuilt relative to the amount of prop we have (15'). There are some direct-tied units with about the same amount of copper (and magnets) with 17' rotors. The idea is MPPT should let us start at a bit lower cut-in, and be efficient in low to moderate winds. If we forego a bit on the top end because the alternator is more robust than we have blades to drive it, I'm okay with that.
As Flux points out, time will tell if this all works as planned, but I thought I'd describe the thought process to this point. Still much to learn, and many spots to fail...
~kitestrings
