Anyway, my input then from a newcomers point of view will be a question. I have read many times about how important it is not to draw the battery voltage down too low, 12.2 is often mentioned, but is this load or no load conditions? I can be running something off my bank and see the voltage under load drop down below 12 volts but as soon as I disconnect the load, in just 30 seconds or so the voltage is back above 12.2 So I think a good FAQ would be how to measure this low voltage threshold assuming your inverter doesn't do it for you. Sorry if it was already covered.
Good luck Woof and thanks for taking the time for this. Andy
I think I got it from the Home Power magazine website's archive. If it can't be found there, anyone who wants me to e-mail the PDF, just drop me a line.
It would also make a good addition to the links in this site's FAQ's. Steven Fahey[ Parent ]
Obviously, this would require clearer thinking than is usually exhibited here. And if I'm sounding cranky, it's because I am. I getting tired of the stupid mistakes. Unities for units? My Gawd! GeoM[ Parent ]
Hey, whadya think the Diaries section is for? We love showing off our stuff.
If you think you're in a cranky mood, type whatever you want, then delete the message instead of posting it. I find it helpful sometimes, just to get myself in the right frame of mind. It's all just a bunch of light and dark glowing points on an electron gun, anyway.Steven Fahey[ Parent ]
Cheers Bruce S [ Parent ]
