I'm a belt and suspenders kind of guy so I really want to have a UL rated diversion system.
i am NOT a code guy but think our (blue book) emergency diversion setup calls for all the possible charging sources times 150% -max pv plus max hydro 1650w? so a dump capable of dumping 2475watts @ 58v..42amps. just over the continuous rating 40a of the c-40, code might want a max of 32amp loading on that controller?
could get close with two of those diversion heater units you have there. 19.3 amps each @ 58v would get us about 38.6amps dump @58 volts or about 2.2kw. WOW doz is alotta clams!
c-40 voltage adjustment: we need to check that the *jumper is on the top pins (charge controll)..find a clean place to move these tiny jumper pins over.. easy to drop it hard to find it! ..especially in tall grass
*page 20 of manual.
that resistor mod page 26 is an extra offset for NiCad batteries. we should not have to go that high..it changes the adjustment from the stock 52v - 60v adjustment to a new range of 60v - 68v for the bulk charge settings.
andy, i'd be nervous leaving the charger function enabled on that inverter/charger in this system.
looking forward to seeing that "hokey" video when i get to a better net connection..my dial-up takes 30 minutes per minute of video to download and run
cheers, dave
