Hi!
On my search for a Non-µC-MPP-Tracker I found the solar_mppt.pdf at your board (I also attached it). Next Friday my team and I will participate in a solar-modelcar race and we are still working on the electronics. So need some help quickly.
The circuit in the .pdf named above has been the cheapest I had found, so I ordered the parts and tried to make it work. But it seems like I have failed. In the past two or three weeks I acquired some knowledge about all this MPP and Buck-Converter stuff, but I don't have any experience with it. So it is kind of hard getting through it.
This morning I finished soldering and checked the circuitry. But it didn't work as I expected. Using an ordinary power supply at the input and a changeable load at the output I could not see any current flowing through my digital meters. I really do not have a clue, if I did a mistake or even if the circuit is really what I have searched for.
So I need to know, how this circuitry is supposed to work. That's what I read out of it:
- it keeps the solar panel working at an preset voltage (via P1; I could not make any adjustments with it in my test)
- it also works like a buck-converter (for instance: it keeps the solar panel working at 12V and the output voltage is adjusted to continuous 8.1V)
The solar-car is powered by a 20w solar panel and it needs to recharge a 7.2V NiHM battery during the race-breaks. I know that the panel is underpowered to fully recharge the battery, but it is not supposed to.
My questions:
- My assumptions are right? Or do I need an extra buck-converter?
- The datasheet for the 78S40 shows another value (µF-Range) for C2 (controls switching freq.). What is the switching frequency supposed to be with the 1nF capacitor?
- Or: What is the minimum value for the inductor?
- How do I set input and output voltage to the value I need? (adapt R1/P1? What is P1 for?)
- Is there a chance to make it work the way I want it to?
I hope somebody can help me with these questions. There is not much time left, but a long way to go... it's kind of frustrating.
Greeting from Germany and sorry for my English
