It's all good...
I did get the link to the page, but couldn't recall if they were fast enough to be used for rectification.
I'll probably order me several of them when the finances straighten out a little around here. Right now everything that wasn't already pretty much rolling has been put on pause until I can locate another suitable means of income. Friggin economy.
As far as working with the new mppt, I'm sure it will be fine, it benched ok, right? The biggie between bench and panel performance that I found is the caps! Caps caps caps! Don't forget!
There's a couple of other things that I've been playing with that may be worthy of mention for use in version 2 -
I've been dinking with the use of a battery as a kind of cap. Currently I only have it on the output, looking to put something similar on the input in the near future as well. Re-borrowed the concept from the attempt with the LiPo cells (which failed miserably; I don't think the control circuitry in each cell particularly cares for the voltages that get seen when that many are put together in series... ?). Went with lead-acid this time.
The output side has a 'sacrificial' 12V 5AH SLA that runs pretty high most of the time when the system is in operation (14.7-15V, thanks to the incorporation of a Schottky diode afterward, hence 'sacrificial'), but it is close (electrically) to the output of the buck, and smooths out the pulses rather well. Afterward, the mentioned Schottky diode provides main battery discharge protection, but of course also gives a 0.3-0.5V drop depending on current and temperature. This 'battery-cap' will of course burn all it's water up eventually, but ATM it seems like the only real viable solution to an annoying problem.
Worked out the theory on paper, and even with the drops from the Schottky, it does in fact appear to be driving the
overall system efficiency up a couple points by significantly reducing the high current pulses that are still coming out of the buck. Still plan on shortening the leads going in and out of the control modules (buck and dump) to further increase efficiency. Noticed a significant drop in efficiency when I went from the very first smoke tests with this to the currently 'installed' version. There's a big difference between a battery being 6 inches away from the output of the buck and 6
feet away. Losing just over half an amp from this!
I've tried to keep the lengthy runs on the higher (wild) voltage coming from the panels, and then do all the conversion and processing as close to the target battery as possible, but even with that, I was still getting losses from lack of filtering.
Going to also try something similar on the input; have done it as a very basic conceptual test, not quite sure of all of the potential gains just yet. Pros vs Cons still need to be weighed in this part. The battery is going to need to need to be ~30V for my particular layout. Was considering two 12V and one 6V @ 3AH, but finding that the peak power from the panels is typically at a slightly lower voltage than originally designed with in mind, so considering just two 12V 3AH in series for 24V nominal. They of course are going to boil dry rather quickly too, so again, this is not ideal, but the use of a battery very close on the input side significantly reinforces the 'stiffness' of the buck in general; with both input and output, efficiency is much better than without either.
Simply here FWIW, you may want to consider playing around with this as an idea. Caps would be better in terms of 'proper' obviously, but at the power levels we're dealing with (particularly as they increase), filtering and hardening are going to be more and more important. Unfortunately it's difficult to get the stiffness that these things demand with just capacitors alone.
... Unless you want to try an entire
bank of them haha But even then, while each one added helps, and I stiffened both the input and output on mine with as many smaller caps as I could fit under the board when I tweaked the last revision, no amount of capacitor seems to have as great an effect as a battery.
Steve
