if you can, find an old "motors" manual from the 50's they
have an excellent section on generators and the regulators used to control them
used book stores usually have a copy and i would not expect to pay over 10 bucks for one.
as a matter of fact if money is an object, go ahead and buy one, and after you are done pm me
and i will buy it off you. i collect old tech books and don't have a 50's motors manual for reason.
those old regulators used with the generators are so cool in that they are electro mechanical in operation
you can tweak them to do exactly what you want out of the genset with little more than a screwdriver
and maybe a pair of needle nose pliers.
there probably is a black box regualator in there somewhere, may even be a delco for all i know.
it ought to be about 3" tall, maybe 2.5" wide and about 5" long give or take a bit.
should be three terminals with screw posts if it is a delco or equivalent. the generator output goes through
the regulator, so follow the heavy wire off the generator output and see if you can find the regulator.
it may be something as simple as it is stuck! maybe needs nothing more than taken apart, cleaned, points touched
up with a point file (remember those), and adjusted for proper operation.
i can't imagine that there is any DC generators ever built that did not have an electromechanical regulator somewhere
in the system. if however it turns out that it does not have one, i would study the schematics in the motors manual
and insert one into the unit. if it is an ancient unit it will need some help with the brittle/cracking/chewed on wiring anyway.
bob g
