After about 5 months of operation, I have convinced myself that I will never get any decent amount of power out of it at 12v. I think to date, I would estimate my power output at about 1 Wh or 3600 joules.....
So it is time to reconsider the design. My plan is to make a VAWT with a 1 meter height and diameter. Two blade, savonius, with airfoil shaped blades.
At first, I plan on makeing this a 1.2 volt machine, not a 12v, so my cut in will be at roughly 45 rpm, which is much more manageable. Cut in wind speed would be approximately 7 mph for charging instead of 18 mph for my current windmill.
The blades will be made of many 1" wooden slats that are about 1/4" thick. I will at first charge my 2500mah Nimh cells to see if it works. If it does, then I am planning on buying some 9 Ah nimh C-cells.
I found some that were about 5.30 Wh / $ , which is an amazing deal in my mind as they were only about 3 Wh/ $ two months ago. The batteries would only cost me about $22, which isn't that bad.
If I wanted to, I could scaled it up to any multiple of 9 Ah. With a 9ah pack, I could run my laptop for a whole day or my tv for a few hours and feel that I have actually done something significant.
My only concern is that the treadmill bearings will not like the vertical position, especially with a 10-20 lb blade on top of it.
Peak power would be about 25 watts at 10 m/s, about 5 watts at about 6 m/s. The motor is good for 16 amps continuous, so I think I will be fine on that front. I have yet to get any rpm to power graphs, which I hope to do somehow.
Any criticism would be nice. Construction date would be no earlier than this weekend. I don't think I set my goals to high
